Mac OSX 10.8.4 flash problem
Greenfielt
Post by Greenfielt »
I've got a frustrating problem. I've downloaded the new (demo) version of Resolume Avenue 4.1.6 from the website. All the videosamples are working fine, but when i try to use for example: Tweener, or a downloaded dynamic SWF file it won't open.
I am able to edit all the preferences, but the flash file itself won't show.
Anyone got an idea what is wrong?
I'm using the following config:
Macbook Pro Retina 15"
Core i7 (2,8 Ghz Quad Core)
16GB memory
768GB SSD
Re: Mac OSX 10.8.4 flash problem
Resolume can not work with the latest flash player (11.8), you need to downgrade to version 11.7 and it will work again. You'll find instructions and downloads on the Adobe website:
http://helpx.adobe.com/flash-player/kb/ ... sions.html
This issue will be fixed on the next free update (4.1.7) dropping in about 2 weeks from now.
Greenfielt
Thanks for the quick reply, this indeed solved the problem.
:mrgreen:
