at first I want to say that i´m new in this forum and my english is a little bit bad. So I don´t matter, if somebody will give me the answers in german^^ Hopefully you will understand me
So I have to build a setup for an event, with two live cameras and seven beamers/projectors. But there should be three of this seven projectors, which should stream a big wall for advertisments. The other four projectors should show the live cameras. I want to make transitions from one cam to the other and sometimes a few clips. I only need one output on my output/video card because i can splitt the signal to the 4 projectors. These four projectors should always show the same but they will be stream at different places.
Here´s my actual workstation:
OS: Win 7 Ultimate x64
Software: Resolume Arena 4
Processor: 2x Intel Xeon E5-2630 (2x 15 MB Cache/ 2 x 6 x 2,3 GHz)
Motherboard: ASUS Z9PE-D8 WS, Intel C602
RAM: 32GB ECC DDR3-1333 (4x 8GB)
SSD: 128GB Corsair Force GS (555MB/s read) (for the clips to play in resolume)
Second SSD: 380GB Corsair Force GS (for the operating system)
Hard Drive: 500 GB (for Stuff)
Graphics: Nvidia Quadro 4000 with 3 Outputs but I can only use 2 at the same time.
At this time I have to say that I´m using this workstation to create films in 3ds Max / After Effects / Vegas etc...
not for resolume or live shows. Actually I wanted to upgrade with an nvidia tesla C2075 to nvidia maximus technology for better / faster computing.
My problem is how can I build in 2 sdi inputs and 5 video outputs(1 x Resolume Software + 1 x Mixed Cameras(splitted up to 4) + 3 x Advertisment Projectors.
So I need more video ouputs and inputs to make this possible.
After a lot of research (resolume forum/nvidia/ati/blackmagic) I heard that more than one card would be difficult to accept in Resolume. I thought I have to buy a nvidia sdi capture card and a nvidia sdi outputcard. If I do that, the cards would all work together, but that would be very expensive.
SDI in/out:
http://www.nvidia.com/object/quadro-dig ... eline.html
So I decided not to buy a capture /output card which fits to my quadro. I want to install a second OS, with another new card.
At first I wanted to take the Nvidia NVS 510. It is made for Multiview - uses. It can use 4 Outputs at the same time. This card would be perfect if i would use some tripple head to goes / dual head to goes. But I think this solution would have to much delay.
NVS 510:
http://www.nvidia.de/object/nvs-510-gra ... pContent=2
So my latest idea is to use an ATI HD 7970 GHz Edition of Asus:
http://www.asus.com/Graphics_Cards/MATR ... /#overview
It is a gamer card and not optimized for rendering images or something other numerical problems but I think it would be enough. It has 6 Outputs. So I can use 1 x Resolume Software + 1 x Mixed Cameras(splitted up to 4) + 3 x Advertisment Projectors + 1 x Monitoring Output on another display for me.
As I said before, I want to install a second OS, so that the quadro card would only work on the first OS and the AMD card on the second OS. I want to run resolume and the capture cards also only on the second OS.
I also need video inputs for the cameras. I want to buy 2 x Blackmagic DeckLink Mini Recorder cards:
http://www.blackmagicdesign.com/product ... pecs#35424
ATI, Nvidia, Resolume and Blackmagic says that they would be compatible. But on some pages they say that you have to pay attention beacause not everything will work. Nvidia says that if i buy the SDI Output/Input cards of Nvidia, they would work all together(also Blackmagic cards) very fast. But i want to use this ATI card. I´m not sure that resolume recognizes the Blackmagic cards. I know that the ATI card won´t work together with the blackmagic cards but it should only compatible. The Blackmagic cards would be calculated by the proccessor,wouldn´t it ?
So my latest Setup:
Graphics: Nvidia Quadro 4000 (but not in use)
2nd Graphics: ATI HD 7970 GHz Edition (of Asus very important!)
Capture Cards: 2x Blackmagic DeckLink Mini Recorder
Can somebody check this setup ? Does it work ? How much delay will be ? Can I use two DeckLink cards (live cameras) at the same time ?
I hope somebody can take a little time and help me ...
with kind regards,
schLega
