NEW IMAC
NEW IMAC
Hi all, im planning to upgrade my media server to the new Apple Imac with NVIDIA GeForce GT 650M due to the frequent system crashed and so on. So is there any issues that should i take note regarding apple imac? And yes, im totally new to the mac world
Re: NEW IMAC
hmmm.. will you use this imac on serveral different jobs? or will you buy it for one specific location? and if yes... what kind of clips you are going to play (resolution, amount simultaneously)?
Do you like outlines? Easy Outliner on Juicebar Re: NEW IMAC
Yes, will use it for several different jobs. Mostly used resolution is 1920x1080 composition, up to 7 layers for now. Sometimes need to play clip with sound. only use 1 output, to the datapath .
Re: NEW IMAC
In this case I would recommend you an iMac with a better graphic card. There are iMac's available with the GTX 660M, GTX 675MX or GTX 680MX.
Greetings
EDIT//
I would also recommend you a SSD!
Greetings
EDIT//
Where to get the gtx version? Im pretty they only hv gt650m on their site. How about the heat issue? Sometimes we r working under the sun
Re: NEW IMAC
Another question. Can macbook air with intelhd 5000 run resolume?
Re: NEW IMAC
You'll find the gtx cards only in their 27" iMac.
I don't know if it is possible to run resolume on an airbook.
Greetz
Greetz
Resolume will start up with the Macbook Air, but forget about 7 layers or anything at 1920x1080.
Re: NEW IMAC
Or using the Advanced Output. Or the chroma key effect.
In fact, we suggest to just forget about using Resolume with a Macbook Air.
Re: NEW IMAC
haha..thanks for the input. thought wantd to buy an airbook just for backup, i'll get a dell for that instead. any tips to improve resolume performance on imac?
