Layer transform vs clip transform
Hypnotist
Post by Hypnotist »
why clip transform changes layer size? What is point of having layer transform tools if those are not independent from the clip transform? This is not working logically. Affects both Arena and Avenue.
http://ljhypnotist.com
iMac 12.2, 3,4GHz/16GB/HD6970m 2GB/TB SSD-raid/DH2go
Arena 4, Modul8, Arkaos, MAX, QC, Unity3d, Madmapper
Launchpad,Maschine, RemoteZero SL, Bitstream 3x
Hypnotist
Re: Layer transform vs clip transform
Post by Hypnotist »
I made lil video to help you understand what I mean
yochee
Post by yochee »
use the FRParamerters plugin on clips/layers. it is independent from the native clip transformation and way better!
Hypnotist
Post by Hypnotist »
yochee wrote:use the FRParamerters plugin on clips/layers. it is independent from the native clip transformation and way better!
I don't want to use plugins for basic functionality
bildwerk
Post by bildwerk »
we also noticed the same bug last weekend....
drazkers
Post by drazkers »
Just add the mask after you've sized all your clips. I've actually found it added some functionality with mapping effects. I assumed that was the system they intended, but maybe it is a bug.
Hypnotist
Post by Hypnotist »
drazkers wrote:Just add the mask after you've sized all your clips. I've actually found it added some functionality with mapping effects. I assumed that was the system they intended, but maybe it is a bug.
this is not only about the mask. it is about the layer also. I see no reason for two controls if those do exact same thing...
The way Resolume works is that the layer controls are sort of a shortcut for the clip controls.
Everything you set up in a layer will affect all clips in it. Using the layer controls is probably the way you want to run most of your shows (if you work with more than two clips).
Sometimes there is a particular clip that needs to be finetuned, and then you can use the clip controls. All transformations will be merged with the layer controls and then rendered in one pass.
The idea is that you for instance scale down all your clips to 50% on the layer, and then have one clip that requires it scaled up to 200% on the clip. This particular clip will then render at its normal resolution, without loss of quality.
For more info on masking and transforms, I suggest checking out the masking chapter of the manual, particularly the paragraph on the render order: http://resolume.com/manual/en/r4/masks#render_order
Hypnotist
Post by Hypnotist »
goto10 wrote:The way Resolume works is that the layer controls are sort of a shortcut for the clip controls.
Ah! Solution was quite easy!
