Hi all.
I have two users set up on my Mac (Mountain Lion), let's call them user A - for the everyday use and when working on softwares and user B - for when I am VJing with Resolume (with no extra softwares installed for better performance).
I downloaded Resolume 4.1.7 on user A and installed it for 'All users of this Mac", it opens fine when I am logged in as User A but when I try to open Resolume on User B it won't open. Finder window flashes (as it normally does when you open an application) but Resolume never opens. When I single click on Resolume icon the 'last Opened' field shows the time and date of the last time I tried to open the software, so the OS shows the software was opened.
Version 4.1.6 still works and open fine, no problems at all. Never had this problem before, every time I installed the latest Resolume version (on user A) I could open it when logged in as User B. Both users, A and B are 'Administrators'.
I already tried different things such as:
- Verify/repair disk permission - it did not fix the problem
- downloaded and installed 4.1.7 straight to user B - it did not fix the problem
- moved config.xml and compositions files out of resolute app folder - it did not fix the problem
Suggestions?
						Resolume 4.1.7 does not start on a different user
				Alvis_Cortex
Re: Resolume 4.1.7 does not start on a different user
This indeed seems to be broken on 4.1.7. We'll make a ticket for it and see what we can do.
Thanks for letting us know!
				Alvis_Cortex
- Tschoepler
+1
						- Programfeed
Has this been addressed in 4.1.8?
+1
still happens in 4.1.8
				deepvisual
is there a work around?
				deepvisual
any news on the new release that fixes this bug?
I need it for a gig in 5 days time
The 4.1.9 release will not be out in 5 days. If you need to work with multiple users, you can download 4.1.6, where multiple users does work.
