Animating video clips via external audio sources
minniemouse
Post by minniemouse »
Hello!
I'm quite new to Resolume. I have Resolume 3 (Avenue) and I need to know exactly how I can control video clips loaded into the software via an external audio source. For example, I'm thinking of inputting sounds from a microphone into my PC and I'm hoping that Resolume will be able to use these sounds to animate a selection of video clips. I'm not very technically minded - what's the simplest way of doing this? Thanks! :)
Rene
Re: Animating video clips via external audio sources
Post by Rene »
Hi minniemouse,
I'm not sure what you mean by "animate a selection of video clips", but you can animate parameters of videos / effects / video sources based on external audio.
I suggest to read the manual section here, just search the page for audio analysis
Hope that helps.
