I'm trying to get sync from a click track from the drummer. Basically I just need to press play when the click starts.
Is there any way to actually do this from Resolume? Is there a 3rd party app that could sync this?
Using Click Track instead of SMTPE
deepvisual
Re: Using Click Track instead of SMTPE
get whatever is playing click to send a MIDI trigger, or stripe a seperate audio channel with timecode - which is what I do.
Could you tell me in detail how do you do this? i also need this for the pro tool click on the last click to send a command via midi or sound to trigger a play on a video in my resolute, how can i setup that?
deepvisual
you map thecorrect MIDI note to the clip you want playing, then send MIDI into your computer. point resolume at the MIDI source and that should do it..
Thanks mate
