The question to the Topic:
Have some of you allready tryed this new technologie and can share any experience with the community ?!
Heard about some FPS drops and/or bad performance in generell.
Is this still so bad, even with the latest version of Optimus ?
Any review is helpfull.
Thank you all.
Nvidia Optimus ?!
Nvidia Optimus ?!
~Berlin~
~Berlin~
Re: Nvidia Optimus ?!
You can turn off the optimus and use your dedicated Nvidia card at all times. Initally i had the same concern but since i use a laptop with optimus, I can tell you that it works absolutely fine with resolume, if you turn off the optimus and use the dedicated NVidia card always.
i cant realy turn it "off" i just can set the Nvidia card als default to use and assigning resolume to be urn with the card... but so faar it work also qithout problem...
~Berlin~
~Berlin~
