Scroll to Column on trigger
hi,
I would like to see an option to enable Column "focus" on external/keyboard column trigger.
Best solution would be to center the triggered column in the window to see previous and next columns too.
Also, the same for layer select.
I will use arena for theatrical work, with mostly linear compositions.
I have already built a program that uses osc for linear triggering with Enter (and some more functions like fade time auto setting), but I'd like to see the next Column without having to switch programs to scroll.
I have seen topics about making the scrollbar midi/osc controllable, but this would be different.
Or have I missed something like OSC: /track#/focus ?
Re: Scroll to Column on trigger
Yes, this can be annoying. The 4.1.9 update will be all about fixing little workflow hindrances like this.
gabonacorp
Post by gabonacorp »
+1
drazkers
Post by drazkers »
Joris wrote:Yes, this can be annoying. The 4.1.9 update will be all about fixing little workflow hindrances like this.
