PLS help me!
vjdragon
PLS help me!
Post by vjdragon »
how can input chinese in here? and it display is perfect, don't like this
Re: PLS help me!
When using Text in a Flash file, you have to make sure the font you're using can actually display the characters you want to display.
In your case, this means that all Chinese character sets should be included in the embed options of the font. This has to be done using Flash itself. In the Flash .fla file, click on the Embed options in the Character properties.
Screen Shot 2014-01-24 at 11.30.07.png (14.56 KiB) Viewed 2928 times
Screen Shot 2014-01-24 at 11.29.58.png (25.25 KiB) Viewed 2928 times
Hope that helps.
