Hey there!!
just stopping by to say that this multimonitor adapter (CIRAGO HydraDisplay) works great. It works with DVI or DP output of your computer and you get a triple output. Just like a matrox triplehead.
http://www.newegg.com/Product/Product.a ... 6815242003
It´s cheap, works great and just plug and play. BUT way more basic than matrox and it´s also bulky.
I´ve been using / testing it side by side with a matrox triple head  on Arena for a 6 screen width projection and no issues at all.
Cheers.
						CIRAGO multimonitor adapter
Re: CIRAGO multimonitor adapter
That's pretty awesome. Does it support VGA out with adapters?
				manuelgazzo
Good point. Although the dvi connectors are DVI-I, i had no analog signal (vga) using adapter.DayVeeJay wrote:That's pretty awesome. Does it support VGA out with adapters?
Dont know if i missed a setting.
I use them as DVI signals and it works sweet.
The DP edition of the TH2Go requires active adapters for VGA out. I wonder if it's the same deal with this unit.
