Command line DXV conversion
I have to convert my 100gb library to DXV. I love MPEG Streamclip but it doesn't work preserve the file structure. Unfortunately I cant find any documentation on command line options either. Can anyone suggest something that'll run on PC? I can do some batch scripting if needed.
						Re: Command line DXV conversion
im not sure but if you have the DXV codec installed you should be able to use it from ffmpeg
having that i would use cygwin + ffmpeg to batch convert the videos
ffmpeg doesnt work with DXV. The topic has been discussed before.
