Performance
rot_
Post by rot_ »
I have tested Resolume on 2 machines so far - one asus 300mhz notebook on which the performace was quite ok for up to 320*200 but not in fullscreen mode (with 320*200).
The other one is an Athlon 1400 with a tnt card. On this machine the perfomance was still wuite poor with resulolution higher than 320*200.
So who has a machine that works fine with resolume and what kind of harde do you recomend?
the processor is not the problem, (if you do not use VERY complex flash files) you need a fast videocard to run it smothly, so a geforce2 MX will do fine, they are very affordable and fast.
kacis_
Post by kacis_ »
HI,
What about ATI FURY RAGE 128 (32MB, video out/in)? Did some one test it with resolume?
Genoflex_
Post by Genoflex_ »
for now I am testing a matroxG550 with my old pII400 and it seems better with the zoom option than the GF2MX400 that I tested few days ago... the output is great quality, verrrrry simple to set up and the zoom is hardware accelerated so it do not decrease realy the performance... thus in fact i still need some better frame rate with 3 stream... (though it still better than with the GF2MX400)
edwin
Post by edwin »
hi genoflex,
we didn't had the opportunity yet to see the matrox g550 videocard in action.
Can you tell us some more how this zoom option works... and if this is also available on the matrox g450...(we didn't find it so it propably won't ..but maybe you know more than us..)...
