Knob speed control via BPM /apc20
mad es
Post by mad es »
Hi!
I want to control the speed of BPM clips with
the knob on my APC20, but when i map the knob to
the BPM, it slams in 0 or the opposite value when i use it.
Anybody has a fix for this?
Basic
Re: Knob speed control via BPM /apc20
Post by Basic »
Do you mean the cue level?
Its a tricky one and don't think it can be done. It maps but not how you'd expect. It goes from 0 to 127 in one go. this is all off the top of my head so correct me if wrong.
mad es
Post by mad es »
Yep its the cue level. Hmm, so i have get an extra midi pad with knobs then. Kind of a downer since i only need one knob for this :(
Have you tried to switch the mode to relative?
