Footage FPS
dirtyjohn_lv
Footage FPS
Any way to get these prerendered at 30fps as well as 25fps?
Re: Footage FPS
Hi Dirtyjohn,
for a save way I would suggest you to convert the 30 fps clips into PNG/Tiff sequences with obviously 30 PNG's/Tiff's ect. per second...after that your can convert the picture sequences to 25 fps clips.
If your result clips are longer than the source clips...it might worked
Greetings
Greetings
Do you like outlines? Easy Outliner on Juicebar -
dirtyjohn_lv
Re: Footage FPS
I already do a bunch of conversion to get them to 30fps, would just be handy to already have it done
I imagine some of the stuttering playback issues come from people downloading clips from the site and expecting them to playback smoothly, not realizing their refresh is different.
Re: Footage FPS
Interestingly enough, we've discussed switching to 30 fps as a default standard for the footage shop just last week. It's going to take a while to make the transition, but it should be the new standard.
It just makes a lot more sense for digital performance to run at 30 fps because most outputs tend to refresh at 60hz.
Re: Footage FPS
I apologize that I have to disagree with this statement. All corporate jobs I've done in Germany so far ran at a 50Hz refresh-rate. The main Show-parts mostly are done with a media server system like pandoras box or watchout ..ect...and the aftershow parts with Resolume. All those systems have to run @ 50Hz because of all the TV cameras on these events which are running @ 1080i50. Beside this fact the VJs often plug their video-outs @ corporate events onto the video directing unit which obviously also have to run @ 50Hz.Joris wrote:It just makes a lot more sense for digital performance to run at 30 fps because most outputs tend to refresh at 60hz.
Why not offering both 25&30fps clips ?
Greetings
Do you like outlines? Easy Outliner on Juicebar Re: Footage FPS
Good point and thanks for chiming in!
Offering both is not an option. People already complain the downloads are too big, because they think they need to download both the Pjpeg and DXV versions.
It would be easier to re-render 30 to 25 than the other way around, right?
Re: Footage FPS
Hi Joris,
you already wrote it down: because they think.
How it looks right now:
It's not that easy many people think it is I guess.
Which company do you think will hear things like "your shopclips stutters more than others" first?
Most of the people who think that the downloads are to big because they downloaded every offered link under their purchases will not be able to convert the clips to a suitable fps right. I think you know what I'm tiring to say?
Greetings
It may be a solution to redesign the download section just a little bit so even people who are not that familiar with fps'ses & videocodecs know what to download.Joris wrote:Offering both is not an option. People already complain the downloads are too big, because they think they need to download both the Pjpeg and DXV versions.
I think it makes no difference in easyness...but not everybody can do this kind of conversion right.Joris wrote: It would be easier to re-render 30 to 25 than the other way around, right?
Greetings
dirtyjohn_lv
Re: Footage FPS
Cosmowe,
Everything runs at 50Hz because you're in Germany.
It's all power based. Most countries that use 220-240V for power devices refresh at 50Hz (Europe and Africa and Mid-East)
USA/South America and Asia use 110-120V for power so everything refreshes at 60Hz.
Maybe separate downloads by region, still viewable by everyone?
Re: Footage FPS
Ouch. Right where it hurtsWhich company do you think will hear things like "your shopclips stutters more than others" first?![]()
