Low GPU utilization
zechs3
Low GPU utilization
Post by zechs3 »
Hello all,
I have a 6 output via 2 x triple head to go. The projectors are running at 1280 x 720.
Driven by a GTX 780 and i7 4770k CPU, with 8gbs of ram.
I am using the two DVI's on the 780 for my displays and the HDMI for control/UI.
I am playing mov files from MotionLoops.
My GPU never reaches higher than 20% utilization. And worse yet, the performance drops when multiple layers are used.
Are there settings or codecs I am missing maybe? Everything works as far as output.
Any insight from another user would be helpful. Thanks!
Re: Low GPU utilization
Hi there....
do you recoded your footage to the dxv codec which comes with resolume?......no?
...try it.
greetings
zechs3
Post by zechs3 »
I am definitely willing to try, is there a recommended method to doing these files in bulk?
MPEGStreamClip is a free tool....
greets
philthehorror
Post by philthehorror »
Definitely make sure you are encoding all files to the DXV format, and furthermore, you follow the specifications listed in the Resolume guide (audio seperate, alpha channel on, etc.) DXV is the only way to fly in resolume....
***EDIT**** See here http://resolume.com/manual/en/r4/optimi ... ring_media
