Split a 2160x576 signal in 3 screens
Well, I was wondering if with resolume and a potent graphic card (which one?) I could put 3 4:3 signals divided in the 3 layers of reslume to be projected everyone in a diferent screen but the total signal would be one image with the total size of 2160x576....
therandelman
got ghz?
I think, this could be possible!
I would recommend t check out the MATROX site, they are the only company which produces grafic cards with 4 outputs I know.
In Resolume, you can configure each output and what you want to have dispalyed (eg. Output 1 - Layer1, Output 2 - Layer 2, Output 3 - Layer 3, Output 4 - Preview Matrix).
If I understand you right, you want to divide one big "panorama image" into 3 separate outputs. If so, it is your job to prepare your footage properly (that the edges fit together) in after effects for example.
But I guess, this kind of use will need a beast of a computer.... no matter what software u use.
anyway, i really like the idea. good luck!
[Edited on 1-12-2004 by therandelman]
therandelman
trial and error
i just noticed your thread on vjforums.com! there are various prosperous sounding solutions for your idea. only one way to find out which works: try it!
Anonymous
Thanks for the support
Je je, yes I agree, I will have to try it anyway. At the moment I have a mess on my brain cause I have lots of information and I don't know from where to start but trying it is the only way to make up my mind. Thanks therandelman
Anonymous
therandelman
stay MATROX
compared to some of the latest consumer gaming card prices with ATI or GeForce chipsets, yo can easily get a MATROX card with quad output support (G450 MMS, G200 MMS) prices start at ⬠400.-
if you already have one matrox, you might experience less compartibility issues, than when mixing brands... just a thought...
