transform presets
coz3r
transform presets
Post by coz3r »
this seems so simple i wonder if it already exists and I just havent found it yet.
It'd be cool to have transform presets to be used a later time for new incoming clips. I know you can select multiple clips and change things but that doesnt necesarily help with clips i havent finished making yet:P Just a thought
Sadler
Re: transform presets
Post by Sadler »
There's FRParameters...
http://www.1210visuals.net/
djsimshady
Post by djsimshady »
is FRparameters the most common way to do this? It seems that if it was OOTB that it would be much easier.
how about using the layer transform controls?
