hi is there any way to randomly switch between columns !? i coldnt figure out a way to do it...
maybe with an external tool sending midi (?) signals ?
any ideas greatly appreciated !
thx
Steve
auto column switch
thedawjones
Re: auto column switch
Any daw or standalone midi hardware/editor/player routed into resolume (via midiyoke, loopbe etc if on pc)
can control/trigger/pitch bend resolume parameters, either manually or with predefined midi clips.
-Create clip, with note(s) in clip, play clip, hit midi mapping mode in resolume, select column (or other parameter) to be mapped.
e.g.: Within ableton live there is a random midi effect, that I use occasionally. This also allows me to adjust the
effect parameters such as scale and chance, to indicate which notes are randomized and how often.
This can be achieved locally or over a network.
good luck.
good luck.
mhhh not sure i follow what you're talkin about !??
using ableton to send signals to randomly switch columns ? am i right ?
not possible at all using internal resolume stuff ??
