Animated masks
steveRMD
Animated masks
Post by steveRMD »
i don't know if this has been requested before but the abilty to have animated masks (f.ex. using a stingy sphere) instead of just jpgs would be a great addition !
Re: Animated masks
hi,
try to put your mask video in a layer above your clip, and set this layers mix mode to multiply,
Use a black&white clip for mask video if you want to preserve colors.
steveRMD
Re: Animated masks
Post by steveRMD »
thx for the reply... i was actually talking about the mask you could put underneath the transforms of the clip f.ex. the place where you can put a black/white jpg or other still image...
an animated version would be cool ;)
just a thought
subpixel
Re: Animated masks
Post by subpixel »
I posted a method to achieve this effect using Layer Routers.
See viewtopic.php?f=12&t=11766
In the following comments I posted a detailed example.
Cheers,
subpixel.
