Question about distance of projectors
joaosilvaa
Post by joaosilvaa »
Hi again,
i started work in a club recently, and the most powerfull thing they got to get a good ambience on the club is the projection! but no1 working on it on full time! so on my spare time, during the weeks i try to improve some things and get the maximum perfomence of it.
we're using OPTOMA H180X:
Native Resolution: WXGA 1280 x 800
3000 ANSI Lumens
atm using VGA cables, but i bought new HDMI...
and i want to project on this surface:
https://scontent-b-lhr.xx.fbcdn.net/hph ... 8071_n.jpg
actually we use 2 projectors for a 9x3 cube projection...
it is possible to do with only 1 projector?
or what distance can a projector like H180X can handle ?
Other spare question i got...
What composition resolution is best to use?? max projector resolution?
reggards ;)
joao
He2neg
Re: Question about distance of projectors
Post by He2neg »
  • Projection Lens F/2.5~2.67; f=21.8~23.98mm, 1.1x Manual Zoom
    Throw Ratio 1.55 - 1.7:1
    Projection Screen Size 0.69 – 7.65m (27.2” - 301”) Diagonal 16:10
    Projection Distance 1.2 - 12 metres
    Zoom Type 1.1x Manual
    Aspect Ratio 16:10 Native, 16:9/4:3 Compatible
~Berlin~
joaosilvaa
thanks... what about the resolution of comp ?
He2neg
Post by He2neg »
put the resolution of your whole output (laptop) on the max ( nativ) resolution of the projector to avoid issues.
And if your system is powerfull enough & your content is at the high resolution as well then go with the same resolution then your projektor as resolution of the ccomposition
~Berlin~
