Virus in new plug-ins???
paull
Post by paull »
When loading the latest version of Resolume 4.1.9 onto my performance PC the AVG started to produce virus alerts. See attached image, I removed the files being shown as infected, but that meant I was not able to use the new video FX.
I tried loading onto my laptop, which had Windows Ant-Virus as opposed to AVG and it all worked fine.
What do you suggest I do as a solution to getting these great FX onto my AVG protected machine??
paull
Re: Virus in new plug-ins???
Post by paull »
Bump....any suggestions please, I would really like to be able to use the new FX. Thanks :D
Thanks for your report, Pauli. We're looking into it, but we're going to need a little more time to figure out the actual cause.
paull
Post by paull »
Thank you so much Joris, loving your software and what it can do.
If you need any more info please do not hesitate to contact me :)
Well, we checked the new version with a few anti-virus apps, as well as submitted the .dll files directly to a few online virus scanners, and they all came up clean.
Even AVG turns up clean...
Maybe you can simply tell AVG to trust these files?
paull
Post by paull »
Thanks Joris, will do :D
