Images from directory as auto-clip!
dalini
Post by dalini »
I know, this was available within resolume 2 - it's still in the docs - and I found some posts from 2012 - discussing that, and if it may come back. But I can't find current state of discussion as in:
[ ] will never come back
[ ] is already available and must be used like: ...
[ ] best workaround would be: (should have 'live' feeling - no prerender)
Thanks a lot!
Feature I refer to is this one:
http://resolume.com/support/manual/
Getting Started
Step 1: Loading media files
[...] If you drag more than one picture files to a channel, a picture sequence is created in that channel. Activating that channel will play all the inserted picture files as an animation.
Kind Regards,
Dalini, reply2all
Re: Images from directory as auto-clip!
do you mean importing images in a layer and create a slide show with few clicks?
import your images in one layer, then find the layer tab - auto pilot - click on >> and launch any clip in that layer.
the default image duration is 5 seconds.
you can change this in clip tab - video duration (miliSec)
