I have issue with the advanced output when I do mapping of images on projectors located in extreme positions. If my advanced output window is full screen and I drag one of the points behind the right or left menu, I can't figure out a way to get back to it to adjust it.
Is there any way to:
- cycle through the points to select the next one clockwise or counter clockwise?
- scale the content of the center window so that all the points can be seen?
I'm not able to attach an XML file to this post so here is a link to an example XML screen setup file from my MacBook Pro 15": https://drive.google.com/a/oaktownprodu ... sp=sharing
