Importing Clips
vanderzee
Importing Clips
Post by vanderzee »
Hello. When I drag and drop clips onto a layer the thumbnail view is upside down. Is there a setting that controls the thumbnail view orientation? Thank you.
Re: Importing Clips
There was a bug in your version....just download the newest version (4.1.11) of Resolume and your thumbnails will stop making gymnastic.
Greetings
vanderzee
Re: Importing Clips
Post by vanderzee »
thank you
vanderzee
Re: Importing Clips
Post by vanderzee »
The thumbnails of my imported clips are upside down and was told there was a bug in my older version of Resolume that was fixed in 4.1.11. I updated to the current version and this did not solve the problem. Anyone have other suggestions?
Basic
Re: Importing Clips
Post by Basic »
I'd maybes contact support if the problem still persists.
support at resolume dot com
with your log file and some of the clips you are using.
Re: Importing Clips
Resolume stores all thumbnails in a cache for re-use. So previously imported clips will still have an upside down thumbnail, even after upgrading to 4.1.11.
All you need to do is to clean the thumbnail cache. Just delete all the files in:
Mac: /Users/[username]/Library/Application Support/Resolume Avenue 4/
PC: C:\Users\[username]\AppData\Roaming\Resolume Avenue 4\
This will force Resolume to rebuild your thumbnails right side up.
vanderzee
Re: Importing Clips
Post by vanderzee »
something strange on my MBP. I do not have a user>library folder. I cannot find my Resolume logs or the thumbnails previews. thanks for your help!
Re: Importing Clips
http://www.noterepeat.com/articles/how- ... ry-folders
Somehow Apple doesn't trust you to access your own library ;)
vanderzee
Re: Importing Clips
Post by vanderzee »
Apple is soooo good :D & bad :evil: about many things! Thanks, I had no idea :o
