Audio crackling :\
l0de
Audio crackling :\
Post by l0de »
Hi, whenever I have resolume running my audio will crackle, on other applications, even if no audio is running in resolume. The program could be completely idle and all the other audio on my system will crackle.
Some helpful info:
Running windows 7 64
the soundcard is a delta 1010lt
So far I've updated resolume, sound card drivers, reinstalled resolume completely, tried changing the output in resolume to be any other sound card, (tried the onboard, taking it off asio mode, etc) and still whenever resolume is running all my sound crackles and distorts. This is a big problem, I need to run other apps that are handling the sound.
I don't think it's a cpu load issue.
Fixed! It's a usb problem.
Any ideas? Is there any way to disable the audio system in resolume?
Re: Audio crackling :\
Hi l0de,
how did you configure your audio settings in Resolume?
what are the settings of the delta 1010lt?
you can cause crackle with non suitable settings.
Greetings
thedawjones
Post by thedawjones »
What program are you using for audio?! :roll:
l0de
Post by l0de »
It turns out to be a usb problem! After unplugging everything during troubleshooting, I found one port was screwing everything up when things were plugged in to it.
