-support for midi program change msgs. would be very useful for scrolling thru scenes/columns for example. it would also be great to be able to scroll through scenes without triggering them, just selecting them, and having a separate control to actually trigger.
-support for more 'relative' modes for endless encoders (i use a novation twitch, which needs the "2's comp" mode, resolume doesn't currently support this and i can't edit it on the controller so it essentially makes the encoders useless - if i am missing something please let me know!)
-the ability to map the MASTER audio FFT input volume to a midi knob. if i am accepting an audio signal from a DJ mixer and there are several acts throughout the night, each DJ/track/etc can be slightly different levels. i don't necessarily have access to control the output level from the mixer so having better control over the software input level would be very helpful. sometimes on a complex project you don't want to manually retune every different layer or parameter when levels change, you want to be able to just ride the audio levels with a fader. current solution: always annoyingly having the preferences window open so i can adjust the levels with the mouse.
anyway, like i said, amazing software, i've made a lot of wonderful art over the years with it, eternally grateful etc etc
-capsaicin
