Full Dome in Resolume?
mrwhisk
Post by mrwhisk »
Hello Community,
I am currently midway through my master's dissertation, for which I am putting together a performance in a full dome planetarium. The dome uses a single (super wide angle) projector to fill the hemispherical screen.
My question is: How able is arena at mapping to such a surface? I understand that using rectangle content (non-fisheye) will always have it's issues in such a scenario, however my project is a prototype and I don't have fisheye footage.
If arena hasn't got the functionality to do it, might someone suggest other options / apps to feed resolume into?
Thanks in advance,
Your answer and advice will be most appreciated :)
pfelberg
Re: Full Dome in Resolume?
Post by pfelberg »
United VJs just have released Blendy VJ - a full dome application.
http://www.blendydomevj.com/
Paulo
mrwhisk
Post by mrwhisk »
Thanks for the reply Paulo,
Blendy dome looks epic ... but I'm running windows. Any more alternatives?
pfelberg
Post by pfelberg »
Not that I know of. Sorry.
Anyone?
Scratchpole
Post by Scratchpole »
With a single output dome system as mentioned above I think Resolume is perfectly suitable.
It's all about the content!
mrwhisk
Post by mrwhisk »
Couldn't agree more about content :)
It's a mythological journey into the heart of physics, through the belly of the whale...
How would you set up Resolume for a fulldome output then?
Thanks community!
Scratchpole
Speak to the technician in charge of the dome.
Hopefully it is a system with a single DVI/VGA input.
They should be able to supply you with the required warping profile.
