Mouseover mousewheel blendmode change
Hey Guys,
just a little feature-wish for a little faster workflow.
Would be handy if the red marked region you can see in the picture above would allow us so scroll through the blendmodes via mouse-wheel just by hovering the cursor above it.
Greetings
+1?....anyone? ;)
thedawjones
Re: Mouseover mousewheel blendmode change
Post by thedawjones »
I will respond in Cosmowe fashion;
Just buy one of these and dedicate it to blend mode. :P
j/k
+1 to have it as an option
:D you really know me...
and yes..this is the way everyone should choose if they are constantly changing blendmodes in their show.
For preparing up the show at home IMO....the mousewheel feature can be handy.
Greetings
It's a little known option that you can also assign a keyboard or midi note shortcut to the dropdown triangle that opens the blend mode list. You can then step through the list with each press.
Having said that, +1 on scrolling through it with the mouse wheel.
Thanks Joris for this little hint....works!
Some more missing mouseover mousewheel behaviors include
- horizontal scrolling of current deck(Control+mouseheel ? ), and with touchpad this could work without button pushing
- dashboard dial control,
- and maybe Control+mousewheel (+Alt for fine tune) could be useful for tweaking parameters in Composition/Deck/Clip tabs
