Which is better for resolume? A xeon or a p4? Both run at the same ghz ... In general a xeon can do more heavy loads of work, but would it benefit in resolume or not?
Also the p4 has a faster fsb...?
[Edited on 10-12-2004 by NexusIntent]
xeon vs p4
Anonymous
afaik resolume doesnt take advantage of 64 bit yet, so im not sure the speed increase would be the 'best' you could get, unfortunatly we will just have to wait to see if 64 bit is supported by resolume anytime soon.... another problem i have heard about is that the openGL drivers in windows 64bit are not all that good, so that might need to be sorted out before resolume would be able to go 64bit.
