Hello,
We use Resolume Arena 4.1.10, and we like the internal recording functionality and the way the recorded clip is automatically added to the deck.
But we would like to know if it's possible to only record a layer and/or a clip (when it's a video input such as a Blackmagic Intensity Pro)?
Or is there any other solution that will enable us to record a clip from a camera and add the recorded clip automatically to a Resolume Deck?
Best regards,
Xavier
Record a layer or a clip rather than the whole composition
xavier.seignard
Re: Record a layer or a clip rather than the whole compositi
+1 on this. I think the record function is quite limited as it is now. Would love to see some major updates on it… Have not found any good solutions to this for the moment. Any one else?
All the best /Babcom
If you want to record a particular layer, you kan use the advanced screen setup and send a screen with input from that layer to Syphon Recorder. This solves the issue of recording one particular layer, but 'll not put it automatically in your deck.
also with the build-in recording function (where it does drop it into your deck) isn't optimal to use since the recording is not in the preferred dxv codec.
