does anybody of you have problems loading ffgl source effects (feedback, line scape, lines, stroboscope)? Others (gradients, solid color) are loading as they should?!
I experienced this for a while, doesn't happen usually but regularly. Now playing with 4.1.11 I experience I can't load these source fx + I can not apply any ffgl effects to clips/layer/compo which aren't used already at any place in the composition.
Edit: deleted config.xml and fx load as they should.. but when I load my playing composition again, I can't load fx + sources
I find it quite strange, never read about this in the forum, so.. did anybody experience the same problems??
For now I am running 4.1.8 which runs fine
