Bug Triggering FX in Piano Mode and Visuals with Keyboard
hyp
Post by hyp »
I'm having issues when toggling the Bypass of FX that are Key mapped to the number keys (1-9) while triggering Play Once clips. All keyboard mappings are Composition Key mapped.
Here's my setup:
- 3 Layers (Top, Middle, Bottom)
- On top layer, 23 clips set to Play Once and keyboard mapped to QWERTYUIOP[]ASDFGHJKL;' keys
- Middle and Bottom layers contain looping clips
- Top Layer contains 9 Video Effects whose Bypass are keyboard mapped to 1-9 keys (all in Piano Mode)
Bug:
- When I hold down the Bypass mappings of two or more FX and attempt to trigger my Play Once visuals using my keyboard, some visuals are not triggered.
This erratic behavior does not occur if I use the mouse and manually trigger any of my Play Once visuals, only when I attempt to trigger keyboard mapped visuals.
Re: Bug Triggering FX in Piano Mode and Visuals with Keyboar
Bug:
I think this is due to your keyboard not supporing more than 3 keys pushed simultaneously, not resolume bug.
You can possibly fing high end gamer keyboards where you can push more keys at once.
edit:
You can map a key to more than one effect bypass, if that solves your problem.
edit2:
http://superuser.com/questions/73685/ke ... -same-time
hyp
Post by hyp »
Hmmm, not sure that is the case because I am able to trigger 3+ keys using effects and trigger a visual. It's erratic and only happens on certain visuals.
that dependens on your keyboards matrix layout.
you can be able to trigger with 3+ keys if they are on the different side of the keyboard - in another area.
