read flash FPS
levon
read flash FPS
Post by levon »
could you make so that when you load a flash file in, it will read the frames per second from the flash file. all my files are automaticaly set at 25 FPS when they are all around 10-15
thanks
yes we have looked at doing this but unfortunately it is not possible to get this info from a flash (swf) file.
levon
Post by levon »
wow, that is odd that you cant read the frame rate.
