Stroboscope as an effect
ReggieUnderground
Post by ReggieUnderground »
Just like Solid Color is available as both an effect and source, I would love to have Stroboscope available as an effect. It seems like the current Strobe effect is really half of a Stroboscope anyways, no?
Re: Stroboscope as an effect
Hmmm..whats wrong with the existing strobe fx?
Greetings
ReggieUnderground
There are two sets of hue parameters in Stroboscope.
......sorry Reggie....I didnt get it. :) what should a strobe plugin do for you?
Best regards
Cosmowe
He2neg
Post by He2neg »
^Maybe this one is better for your needs ;)
http://www.1210visuals.net/index.php?op ... &Itemid=59
~Berlin~
You can recreate the look of the Strobe Source with two Solid Color Effects, and setting the blend mode of the second one to TimeSwitcher. The opacity will then control how fast you strobe the second color over the first.
ReggieUnderground
Thanks Joris. That's the droid I was looking for.
