One video 3 or 4 times the same or 3 4 small vids
skyzofred
Post by skyzofred »
hello,
I have an important question.
I work with video (dvx quicktime) The videos make often 1 or 1.30 minutes but I don't use the full of time in "one slot". MY question is ; is it better ti put the "same" video in multiple slot or is it better to "cut" it to make small videos and import small videos to put in slot?
regards
Re: One video 3 or 4 times the same or 3 4 small vids
Its better, or better, you'll have less work if you take the "same" clip. It will use the same resources like your other suggestion.
