Missing files in beta 2
VJ MFx
Post by VJ MFx »
Hi all!
It's probably posted before, but couldn't find the answer to it.
I'm using resolume 2 beta 2 for a while now and everything worked ok untill my latest quick this saturday.
When I was browsing to my folders within resolume it didn't showed any of my video files:( except for 2 folders. All my files are avi and compressed with indeo 5.1 or IYUV.
Tried to delete my preview files, but that didn't work. For the time being I copied al my video files to the root of the folders resolume did read. But that is not a solution for me in the long run cause my system is a big mess now:(
Hope there is a quick answer/solution to this one.
Thanx in advance,
Martijn
VJ MFx
p.s. any idea on a release date of the final resolume v2?;)
VJ MFx
Post by VJ MFx »
He guys!
Can anyone help me with this???? got a gig planned for next saturday and hope to sort this out before that time....
pretty pleeeeeeeeeeaaaassssssseeeeee;)
cat
Post by cat »
Try uninstalling then reinstalling, thats sorted some of my problems (its not a long term solution though as I've had this happen mid gig, and had to try and to it again then) If it works then maybe install to a different location as well so you have 2 working copies?
VJ MFx
Post by VJ MFx »
ok first try that then and hope this solves
the problem for now.
thanx for the response cat :)
