OSC, Max for Live parameter follow, ableton
jonhorvath
Post by jonhorvath »
any way to map OSC from Max for Live parameter follower to clip properties? Resolume currently only gives OSC address for destination as (for example): "/activeclip/video/scale".... the "active clip" is the trouble...resolume then applies automation to any clip playing.. I want clip specific>
thanks
Re: OSC, Max for Live parameter follow, ableton
you can address clips directly
/layer2/clip5/video/scale
for example for the clip in layer2 column 5
jonhorvath
thanks ravensc!
