This may be a noob question, but:
When I'm trying to switch from clips, the one that I've selected fades perfectly but the one that must fade away doesn't fade away, in fact, it stays until the second clip faded in and then dissapears.
How can I fix this?
						Not fading correctly
Re: Not fading correctly
Also, I'm not experiencing fps problems, and my graphic card is fine.
How did you set up the Xfade between clips?
Also can you give the details of your comp (size of comp and clips, # of layers, decks, clips, etc...) so that we can help you figure out your FPS problem?
which resolume version?
Arena, 4.1.8
I have this issue with simple solids made in Arena. My FPS is stable at 45+ fps.
upgrade to 4.1.11
this issue is fixed.
