faking active outputs under windows
sikanda
Post by sikanda »
i´m planning on a gig where i want to map 9 outputs.
does anybody know a way to fake that there are monitors pluged if they are actually empty for testing the performance possibilitys?
would be greatful for tips.
Re: faking active outputs under windows
In the Advanced Output, just create as many Screens as you need and set them to 'No Display', using the resolution that the actual output will have later on.
Screen Shot 2015-01-16 at 13.10.57.png (14.75 KiB) Viewed 7372 times
sikanda
Post by sikanda »
thx. just found out. sorry for the stupid question
DayVeeJay
Post by DayVeeJay »
You can use the advanced output window to preview your outputs. On OS X I sometimes use air display to fake an output. The computer thinks theres a display attached after I shut off my android tablet
