hi there i've got a project where there are 4 projectors and a monitor connected to one main server and i'm running the resolution of 1024x768 for the each projectors running different videos and triggering all the videos at same time
so pls suggest me a card which can support 4096x768 (as my calculation)
6 output cards
Re: 6 output cards
Should be no problems! Many posts on this. Some keywords to look for: Eyefinity 6, Matrox TH2G, Datapath X4, Displayport MST
Re: 6 output cards
Well thanks oaktown how is this card does it supports
http://www.flipkart.com/search?q=Asus%2 ... To=139%7C8
OR
http://www.flipkart.com/msi-nvidia-gefo ... 55d6350729
OR
Re: 6 output cards
These Nvidia cards will only support 4 outputs so you'll have to use a Matrox TH2G or a Datapath X4 to get all your outputs
If you want to get up to 6 outputs from one GPU, I'd recommend the following cards:
- - Any of the AMD R9 series with DP MST Hub
- ATI Radeon™ HD 5870 Eyefinity 6 Edition Graphics
gabonacorp
Re: 6 output cards
just one more tiny thing: if all the outputs plays different videos than you won't need 4096 pixels wide comp, you only need 1024x768 comp with four layers and route the layers one-by-one to every outputs in advanced output settings.
