More quartz weirdness
mowgli
Post by mowgli »
I've just spent an hour trying to figure out why a published Quartz Composer input wasn't working in Resolume although it worked within Quartz (Resolume just displayed a dropdown with no values despite the fact that I was expecting a slider). Luckily everything works now after I changed the input's name from "shape" to "test shit". I don't know whether I should laugh or cry. If I change the name back it stops working.
Re: More quartz weirdness
I don't know what to tell you, Mowgli. It looks like both 'shape' and 'test shit' work for float inputs on our end.
Screen Shot 2015-03-23 at 09.21.04.png (26.48 KiB) Viewed 2997 times
mowgli
Post by mowgli »
Through my years using computers I have noticed my ability to get the weirdest of bugs.
I can add that as this started happening I got a few crashes. The only explanation I can thing of is that Resolume has some kind of cache for variable names in Quartz comps that have already been used within Resolume. Is this plausible?
