Capture card, move clip in deck
thomasl
Post by thomasl »
Small bug with 4.2. I test this on 2 machines...
I was used BMD decklink and intensity cards.
when I put it on deck, do all necesary settings, everything works..
But, when I move this on other clip postion in deck, resolution setings of "capture" clip goes to 0x0pix.
Anybody with similar case?
Thx
Tom
Re: Capture card, move clip in deck
I have seen something similar before, on earlier versions as well, where a capture input would show up as 0x0 until it was actually connected / triggered.
I don't think we have a ticket for it yet. Could you confirm that this is the same issue, or if it's a different one?
thomasl
Post by thomasl »
similar … after moving on other position in deck, size is set to 0x0. After triggering is 0x0 too. Must be set to corect size.
And this move takes some time .
With movie clips it working immediately, without waiting.
What can be a problem?
pro-technical
Post by pro-technical »
Yes Intensity Pro, Put clip of a composite source on the composition, save and close. Reload composition and settings for width and height of clip have changed to 0x0
intensity shuttle usb3 too.
when dragged from the sources into the deck, video size shows 0x0, and the transform setting show the same 0w 0h.
when previewing the transform settings return to default for the set input.
when launching, the video properties 0x0 changes to default.
when clip is moved behavior is the same.
when clip is moved after adjusting the transform w or h, the adjusted parameter does not reset to 0 on move, but resets when previewed or launched to 0w 0h. and does not return to default value at all.
R4.2, Mavericks.
Yes, confirmed and fixed. We'll release the update as soon as possible.
Thanks for letting us know, everyone!
