After testing 4.0.2 so far found the following. Select Advanced Output, save and close. Restart machine Resolume loads with advanced output is disabled. All other versions go back to Advanced Output mode after restart
4.0.2 Advanced Output Bug
pro-technical
pro-technical
Re: 4.0.2 Advanced Output Bug
update
now working, advanced output preset changed screens outputs to no display (after updating resolume from previous version). Re saved preset after changing screens.
