I was wondering what you are thinking about this setup for 1 PC, 14 projectors, all 1280x800. Driven by Resolume Arena ofcouse. All projectors will be edgeblended and corrected for keystone. It's being used in a setup where there's one very long wall (48m x 1,5m) to be projected on. For now, comp size will be around 14000x600 = 8,4 megapixel. That's like 4k resolution.
This is the setup:
I got some doubts whether the system will like 11 outputs, but according to the documentation, this videocard can handle a maximum of 6 outputs, especially using this MST hub. I read in another post about two videocards: NO SLI bridge, and that only one videocard will handle the load. For those interested: All outgoing connections will be VGA. So I use the Club3d Active DP-VGA adapter for the MST hub. And the Triplehead will be outputting VGA natively via an adapter.
What do you guys think? Is it crazy? Or do-able?
 would be great wouldn't it? Or do you have other experience with MST?
