String parameter BPM sync
I am experimenting with some quartz stuff.
I made a simple text renderer, and there is the multi line string as parameter.
Is it possible to sync the line change to the beat in resolume, or would I have to do that in the patch?
Re: String parameter BPM sync
bump.
You would have to do this in the patch.
Ok,
if anyone wants to try it here is the patch which shows the next line of a string on a given signal, which can be beat synced, or osc / midi/ key mapped.
enjoy: http://palffyzoltan.hu/?url=programs&a=textbeatsync
Input your text lines into the string parameter, separated by the given separator, then animate the next_line_signal.
When the next_line_signal gets to the maximum value, the next line is shown.
The actual line number resets on launch of the clip.
v2.
Made some refinements to the next-line signal evaluation, and also added a timeline parameter which you can animate.
If the Timeline is smaller than 0.1 then the line index is reset to the first, so you can use this parameter in one shot timeline animated to have the first line displayed on clip start/relaunch.
The next line signal has to be animated to move to the right (ascending, which is default in Resolume), if the signal moves to the left ie is smaller value than before then the next line is displayed.
get it here: http://palffyzoltan.hu/?url=programs&a=textbeatsync
