Deck loading indicator
Fodder for the bucket!`
I always find myself juggling with multiple decks to spread the load in my comps but you can't trigger clip(s)/columns until the deck is fully loaded and there is no indication of when all the clips are loaded.
It would be great to have a visual indicator such as a progress bar that shows when the deck is ready to use and hopefully how long it's taking to load.
Re: Deck loading indicator
Hi Oaktown.... Here I give you my +1
... a workaround for now is to keep an eye on the bmp square beside the bpm. If it starts running normaly...the loading process is done.
Greetings
drazkers
Post by drazkers »
+1 to this
+1 for a more clear indication.
cosmowe wrote:.. a workaround for now is to keep an eye on the bmp square beside the bpm. If it starts running normaly...the loading process is done.
if you look closely the beat squares stop spinning for the time the source deck is unloaded, then starts spinning again when the new deck's clips are loaded. (try switching to an empty deck.)
When the deck finished loading you can see the layer1 clip1 gets selected even if empty,
so unless you have column1 and layer1 in the view, the window will jump to it, when loading is ready.
edit:
osc workaround
viewtopic.php?f=5&t=11472&hilit=deck+loading
