Store blend modes by clip/column
anthonydiehl
Post by anthonydiehl »
A reeeeally helpful feature would be the ability to store/assign blend mode settings on a per clip/column basis. This way you could program really dialled in looks that include different blend modes, store/assign them to a clip/column and then recall those settings by simply triggering that clip/column. This is the biggest hurdle I see when quickly programming looks for a very linear show (a bands set list, look per song, etc).
Essentially, the idea is to build a look and be able to recall it without having to manually change a bunch things like blend modes and layer order to fully recall that look.
Re: Store blend modes by clip/column
This is pretty easy to achieve if you use OSC/MIDI/DMX to program your shows. All you have to do is change the blend mode(s) right before you trigger clips/columns. You can also adjust the transition time the same way.
in addition, you can have many layers with different settings, without performance drop (when a layer is not playing it is not rendered).
so you can place a copy of your clip if you want a different blend at different places, this is no problem if you use dxv files.
I do these with combination of osc controlled transition time setting, and it is easy to see what is happening during the show.
btw, columns have no properties yet, they are just a placeholder for clips as far as I know.
but it could be interesting to have columns get a properties panel.
anthonydiehl
Sounds like others achieve this via some work around... which is my whole point. If the feature existed natively, we'd all be using it that way. I suppose another way to think of this would be to store blend modes on a per clip basis; a simple drop down menu in the clip parameters that defaulted to "layer determined" but could be manually overridden to a specific blend mode.
That's my 2 cents. I think it would be a hugely useful addition!
We've been toying with this idea as well. Happy to hear people would find it useful.
Assuming the transition timing could be adjusted as well on a per-clip basis, this would not only be useful but it would be a HUGE time saver and simplify the process greatly.
gabonacorp
Post by gabonacorp »
+1 and no limitation would be also nice. Longest transition time 10 sec now but sometimes a longer transition would be really handy.
Programfeed
Post by Programfeed »
+1 clip-specific blend modes 8-)
DHoude
Post by DHoude »
Yup, definitely a feature I could use. This may actually partially replace my preview to master request the other day..
Sadler
Post by Sadler »
Joris wrote:We've been toying with this idea as well.
For 6 years?
