BMD UltraStudio, Atem 2ME & Avenue
platongr
Post by platongr »
Hello everyone,
I'm using an atem 2me console give video feed on some video walls. I'd like to append some graphs on these videos, so i decided to use the avenue.
The question is, can i use the ultrastudio as "out" of avenue and "in" of atem to fill another channel ?
Thanks !
Re: BMD UltraStudio, Atem 2ME & Avenue
Resolume can not output to a capture card, it's only used as an input.
don't you have a hdmi input on the console?
you could use that from a hdmi,or dvi output with a simple converter plug.
