The release notes for 4.2.1 mentioned the following fixed issue:
This seems to respond to the issue mentioned in this thread (sorry - couldn't post URLs) which was determined to be related to the "Clip Start Offset" configuration setting having a value larger than 0. This was also mentioned in this thread (sorry - couldn't post URLs) along with the comment that clearing out the prefs got rid of the problem.[FIXED] Retrigger and Continue modes are confused if clip start offset is set in preferences
I was experiencing similar issues which is why I updated to 4.2.1. It looks like the issues are not entirely fixed, or I misinterpreted the other threads. I tried removing the preferences file and other configuration files (including those in the Library) but this didn't help. Setting the Clip Start Offset to anything but 0 makes the issues resurface.
Here are the relevant settings and deck configuration:
- Preferences > General > Clip Start Offset set to anything but 0.
- Start off with a new, empty composition.
- Assign an audio file on a clip. I used an uncompressed wave file (44.1kHz, stereo, 4:00 length) but the unexpected behaviours also occur with compressed audio files, like MP3s.
TEST A: Unexpected single forward jump
- Make sure the clip is in "Timeline" transport mode and the play mode is set to "Restart".
- Connect the clip, i.e., make it start playing by clicking on the clip.
- Audio playback will start from the beginning.
- After letting it play for a few seconds re-connect the clip (click it again) without stopping playback.
- Playback jumps forward and playback continues from there. If you repeat this test, you will notice that in most cases the postion the clip jumps to was the last known position before you would have disconnected the clip, i.e., by clicking on another (empty or not) clip on the same layer or the position it would have been in if playback had not been interrupted. And it looks like this is somehow kept even if you restart Avenue as long you don't start a new composition (even without saving your composition).
TEST B: Re-connecting the clip has no effect
- From the context of TEST A, make sure the audio is playing.
- Now change the play mode to "Continue" and then back to "Restart".
- Try to reconnect the same clip without stopping playback.
- The clip will continue to play uninteruptedly.
TEST C: Unexpected repeated jumps
- From the context of TEST B, put the play mode to "Continue".
- Re-connect the clip.
- Playback will jump.
- Repeat from step 2. Every time you do this, playback will jump.
TEST D: Unexpected continued playback
- From the context of TEST C, set the play mode to "BPM Sync".
- Reconnect the clip.
- Playback will continue uninterrupted.
TEST E: Unexpected single forward jump playback
- From the context of TEST D, set the play mode to "Timeline".
- Confirm that the play mode is still set to "Continue".
- Reconnect the clip the clip a couple of times to confirm playback is still jumping around.
- Put the play mode to "Restart".
- Reconnect the clip a couple of times to confirm that playback still jumps just once.
- Put the transport mode to "BPM Sync".
- Try reconnecting the clip multiple times.
If you run test A from step 4 in this context the you will notice that the unexpected effect of test A also occurs here. I hope this can get some responses with workarounds that do not involve setting the Clip Start Offset to 0 until an update resolves this issue.
